When using the StatusViewer Application with MIPSDK 2017 R1 on a Corporate System 2017 R1 i got following events:
(1) Output 1 - Output Activated
(2) Output 1 - Output Changed
(3) Output 1 - Output Deactivated
(4) Output 1 - Output Changed
Since the GUI always shows the last message as item state, the output lasts in ‘Output Chnaged’ state. Is this the default behaviour or can it be changed? I expected to see at first the change indication and afterwards the new state.
My second question aims on the ‘InputSensor’-Message. Whats the purpose and when does it occur?
Thanks in advance,
Regards Michael
