How would I go about installing the API Gateway on a machine other than the management server? Is it as simple as just running the download path http://[management server address]/installation/Admin/default-enUS.htm on that machine and then uninstalling from management server or are there other configurations needed.
We are trying avoid port forwarding on the management server but be able to connect to the API Gateway externally.
