We are investigating the possibility of using BriefCam’s event triggers, specifically “person on the ground,” to automatically mark or retain corresponding video segments within XProtect.
Example: If a BriefCam alert for “person on the ground” is sent to XProtect at 10:00 AM, we need to capture and retain the video segment from 9:55 AM to 10:05 AM.
We need to determine if video retention can be programmatically controlled via an XProtect integration. Additionally, we would appreciate guidance on the optimal approach for achieving this functionality, considering both direct XProtect integration and potential independent solutions.
