Integration of overlay (bounding boxes) in milestone
We are trying to place bounding boxes to plate reading events from a Hikvision camera and the camera and manufacturer’s forums give me the following information.
6656
47361
12544
7424
https://tpp.hikvision.com/wiki/isapi/anpr/GUID-328FC5AD-38EA-4409-9E75-996279BF2A46.html
 <!--dependent, the normalized value is the current image size in percentage multiplying 1000 and it is accurate to three decimal places. This node is valid only when <type> is "detectionPicture"-->
 <X>
  <!--required, xs:integer, X-coordinate of the upper-left corner of the boundary frame-->
 </X>
 <Y>
  <!--required, xs:integer, Y-coordinate of the upper-left corner of the boundary frame-->
 </Y>
 <width>
  <!--required, xs:integer, width of the boundary frame-->
 </width>
 <height>
  <!--required, xs:integer, height of the boundary frame-->
 </height>
</plateRect>
but, passing this data to milestone does not place the bounding box in the correct position, so I need help interpreting this data and how to pass it to milestone.
If you have to do a 0 to 1 or other conversions, since the ones we have tried are not accurate.
There is a sample that submits bounding box data, I suspect it will give you the best answer on how this works.
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/boundingboxmetadataprovider/readme.html&tree=tree_2.html
For inspiration, I did a similar conversion based on bounding box metadata returned from Amazon Rekognition:
private static Rectangle NewBoundingBox(BoundingBox bb, DisplayColor lineColor)
    float top, left;
    return new Rectangle()
        // Define the ONVIF rectangle (with 0,0 in the center and 1 to each edge)
        // using the AWS bounding box values that are percentages so scale them accordingly
        // with 0,0 in the upper-left corner of the rectangle to draw
        Top = top = 1 - 2 * bb.Top,
        Bottom = top - 2 * bb.Height,
        Left = left = -1 + 2 * bb.Left,
        Right = left + 2 * bb.Width,
        LineColor = lineColor,
        LineDisplayPixelThickness = 3
The BoundingBox is a https://docs.aws.amazon.com/rekognition/latest/APIReference/API_BoundingBox.html
The Rectangle is a https://doc.developer.milestonesys.com/html/index.html?search=videoos.platform.metadata.rectangle
