We are planning to integrate video streams into an existing UI under Linux.
As already discussed with Milestone, they provide an ActiveX for MS Windows but do not provide a similar control for Linux!
So the proposol was to implement our own solution based on the Image Server TCP/IP Raw Protocol.
I would like to know which codec is used there (e.g. H.264), and if there is any proposal for an open-source library (e.g. libavcodec) to use for decoding.
