We are experiencing an intermittent native crash in our host service that uses the Milestone MIP SDK. The crash occurs during long-running tests that involve concurrent streaming (20+ streams) within our service. The evidence points to a race condition causing memory corruption within the underlying native toolkit.
Problem Details:
- Crash Signature (from dump): um:invalid_pointer_write_avrf_c0000005_vcruntime140.dll!memcpy.
- Interpretation: The crash occurred during a standard memory copy operation in the C++ runtime, indicating that an invalid or corrupted memory address was accessed.
- Triggering Context: The crash is triggered by a PInvoke call originating from a thread running an internal SDK method (BaseLiveSource.PollThread)
Call Path from Dump:
00000063fa8fdee8 00007ff81514fa44 [InlinedCallFrame: 00000063fa8fdee8]
00000063fa8fdee8 00007ff7a84027c1 [InlinedCallFrame: 00000063fa8fdee8]
00000063fa8fdec0 00007ff7a84027c1 DomainBoundILStubClass.IL_STUB_PInvoke(IntPtr, std.basic_string,std::allocator >*, std.basic_string,std::allocator >*)
00000063fa8fdfa0 00007ff7a8421b82 VideoOS.Toolkit.SourceToolkit.UpdateConfiguration(System.String, System.String)
00000063fa8fe1e0 00007ff7a84219c7 VideoOS.Platform.Common.InternalMediaServiceCommon.SetNewToken(System.Object, System.String)
00000063fa8fe210 00007ff7a83f5d8a VideoOS.Platform.Live.BaseLiveSource`2[[System.__Canon, mscorlib],[System.__Canon, mscorlib]].PollThread()
00000063fa8fe2b0 00007ff8051cdf12 System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) [f:\dd\ndp\clr\src\BCL\system\threading\executioncontext.cs @ 980]
00000063fa8fe380 00007ff8051cdd95 System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) [f:\dd\ndp\clr\src\BCL\system\threading\executioncontext.cs @ 928]
00000063fa8fe3b0 00007ff8051cdd65 System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) [f:\dd\ndp\clr\src\BCL\system\threading\executioncontext.cs @ 917]
00000063fa8fe400 00007ff805273e85 System.Threading.ThreadHelper.ThreadStart() [f:\dd\ndp\clr\src\BCL\system\threading\thread.cs @ 111]
00000063fa8fe650 00007ff807206953 [GCFrame: 00000063fa8fe650]
00000063fa8fe9b0 00007ff807206953 [DebuggerU2MCatchHandlerFrame: 00000063fa8fe9b0]
Environment:
- Installed VMS Versions: XProtect Corporate 2025 R2 (25.2.1), 2025 R1 (25.1.2) & 2024 R2 (24.2.3)
- SDK Component Version: 24.2.2
- Host Service: C++ host using a C# wrapper consuming the MIP SDK.
Request:
We need Milestone’s expertise to analyze this crash. Could you confirm if this is a known issue, especially concerning the native toolkit and operations involving internal methods like PollThread, SetNewToken, and UpdateConfiguration?
Are there any relevant fixes available in component versions later than 24.2.2?
