InvokeMethod for creating an Alarm Definition results in Triggering event type is out of range - ConfigurationApiService
Upon creating an Analytics event via InvokeMethod() and obtaining InvokeResult
as an itemType, I save the path and call GetItem(Path) to check for the status.
The configuration item returned from GetItem() doesn’t contain any state in its properties, the following properties were found:
Key: Id Value: 3B8A066C-844C-4395-B85A-3F3E838810B7
Key: Name Value: testEvent
Key: LastModified Value: 2020-08-17T12:43:38.8530000+02:00
so I assumed it’s already created, but when the Id Value mentioned above is entered as an EventType Property in the InvokeMethod() of creating an Alarm Definition I get the error: Triggering event type is out of range.
Only if I wait around 5s~10s between the 2 requests, the Alarm Definition is created.
How do I ensure that the Analytics event is created and ready? Is this the right way to track the state? because it seems there’s a delay
Kind Regards,
Eslam
The behavior you describe is by design. In order to ensure that the Event Server does not overload by frequent changes to the configuration it can be up to one minute before a new configuration is applied. You will have to implement a retry mechanism in your code to work with this in a consistent and safe way.
