Is it possible to read an absolute timestamp from stream sent trough LIVE RTSP from ONB?
Hi !
It will be necessary to know when the frame has been taken by the camera.
Please answer me !
Hey,
It is not possible to get it for each frame - we do not send out that information in Live.
But we do send RTCP message that contains frame actual timestamp - after first frame and then regularly (5 secs for i-frames, 25 secs for others) .
KR,
Svetlana
Hi Svetlana :slight_smile:
Then is it possible with the vod from a seconds ago?
​Or is there any other way I can check the time information of each frame?
In VOD we add the 0xABAC header extension to RTP packet that contains the absolute time (NTP timestamp) for each frame.
thank you ​Svetlana !
