I have read Milestone has Universal driver that provides RTSP links for cameras live streams. Is it possible to get those links from any Server?
Our goal is no get that RTSP links directly after login operation not by copy/pasting that manually.
Using the Configuration API you can add devices, lookup their settings or change their setting, this also goes for a camera device using the universal driver.
This is Configuration API Client sample and it might be helpful for you -
To make it clear. We need to retrieve RTSP Live stream FROM Milestone to 3rd party.
Is there any tool/module/configuration for that purpose?
I ran into a similar question on Developer Forum, might this fit? - https://developer.milestonesys.com/s/feed/0D53X00006WecL9SAJ
