Is it possible to rotate the image from a Matrox Maevex 5150 encoder by 90 degrees?
I am capturing the RTSP using the Milestone Express+ from a radar system which is outputting at 1080x1920. The Matrox Maevex 5150 encoder sees this as 1920x1080 and this puts the image on its side when viewed in Milestone Express+. The encoder has no rotation capability, so I want to rotate using Milestone.
