Is it possible to send email notifications generated by data in an alarm field such as the tag field (CustomTAG), object or other.instead of the source, message or triggering event?
We have the analytics working but we send variable data in empty fields of alarm manager as tag, object or other, and we want to receive email notifications if a specific data or code is presented in that field.
There is a limited number of fields that can be used in rules sending emails.
https://doc.milestonesys.com/latest/en-US/standard_features/sf_mc/sf_ui/mc_notificationprofiles_rande.htm?cshid=9714
As this does not pertain to development but to a general situation you will most likely get better help from the partners active in the Support Community - If my answer is not fulfilling please ask at - https://supportcommunity.milestonesys.com
PS.
If you are asking here because you would like to use the MIP SDK to develop extended functionality: It is not possible to develop an extension for the existing Notification / Mail capability. It is possible to develop a whole new functionality that does not use existing Notification / Mail setup but does send emails based on events or similar.
It is tedious to have the information in the column, but that milestone does not have the option to select the field in the rules or in the notifications profile.
It might be a limitation in the implemented functionality, probably is, but if there is a workaround or similar maybe the users of the Support Community would know..
Maybe if you ask there it will be picked up as inspiration for Milestone to enhance the functionality in future versions..
(If you already have asked there, sorry repeating it again.)
Hi Bo Ellegård Andersen,
yes, we tried with milestone support, but we were referenced to post here because The rules and the milestone notification profile are obsolete, I already have several projects on a list that I have wanted to work on in this way, but I have not been able to because it is very limited and no changes have been made to it in a long time.
OK, then the PS I wrote above applies.
