Is it possible to trigger alarm on smart map from the sdk
I am using the LibraryEventGenerator sample in the sdk to send alarms, is it possible to trigger the alarm also on the smart map from the sdk ( 2020 r2).
best regards
Sensor Monitor sample might be interesting for you as inspiration -
https://doc.developer.milestonesys.com/html/index.html?base=samples/sensormonitor_sample.html&tree=tree_1.html
