I can visualise gstreamer pipeline with testsrc and facesink by using
GST_DEBUG=2 GST_PLUGIN_PATH=./ LD_PRELOAD="./libgstvpsxprotect.so ./libgstvpsonvifmeta.so ./libgstvpsxprotectmeta.so ./libvpsutilities.so" GST_DEBUG_DUMP_DOT_DIR=./dots/ gst-launch-1.0 videotestsrc ! "video/x-raw,width=2500,height=1400" ! vpsjpegtranscoder ! fakesink
But when I try it with make run there is no dot files.
GST_DEBUG=3 GST_DEBUG_DUMP_DOT_DIR=./dots/ make run
Can you suggest some approaches to visualise pipeline that consumes real stream ?
