Is there a known limit on the amount of data 1 recording server can gracefully accommodate?
We are testing with XProtect 11.1a and have noticed that when the recording server is at high loads (around 1 Gbps of data coming into 1 instance) it will turn off and then restore a small subset of the cameras. We are seeing about 10% of the total number of cameras being impacted when this occurs. This is logged in the devicehandeling.log file without any other errors such as pipeline overflows.
I can provide more detail and or logs via email.
As this does not pertain to development but to a general situation you will most likely get better help from the partners active in the Support Community - https://force.milestonesys.com/support/MccSupportCommunity
I tried a general support ticket and was given this forum to post to explicitly.
Sorry to hear it. I believe you should open the support ticket again.
The focus of the Developer forum is development work using the MIP SDK.
