Is there a way to dynamically update the Search Agent filter widget options?
Can the SearchFilter UI ListSelectionFilterConfiguration be updated dynamically based on changes to the timeframe or the results displayed?
Example
imageIf I select “2 hours”, then I want to update the options based on the results. If I change the “2 hour” frame to “6 hours” then it should update the dropdown list with the new option?
It is not possible to update search filter options dynamically.
