Is there a way to retrieve the list of usernames and passwords used in the "Add Hardware" wizzard?
No. Note that if you start Management Client in another PC you will not get the same list of usernames and passwords as you have in the first PC. There is no functionality for getting the list in a MIP Plugin.
Ok thanks Bo. I did not know about the usernames/passwords, thanks! The reason I asked is because we are re-creating the add hardware wizzard for a custom application. Can you tell me if there is any special logic when trying each set of username and password in the add Hardware method or are they just being tried on each selected driver sequentially?
Yes your assumption is correct, each set of credentials are tried on each driver..
