Is there any support with Essentials for Azure Active Directory authentication when setting up as App Proxy for Enterprise Apps?
So I am working with the free version for now, essentials plus. I have windows users already added and can view everything internally. I have setup an application proxy and can reach the login page from the “outside” this is that certain users can remotely view with out the need of a VPN, since over a VPN tanks the connection. I am trying now to get it work single sign on, but would prefer the pre auth to come from Azure Active Directory. The main issue I see so far is that when using AAD for authentication it wants to pass through the full email instead of just the username example, AAD wants to send through username@domain.com whereas with the web client login for Xprotect it just wants username, only since it does not appear that at least with xprotect essentials supports native Azure Active Directory Authentication. Just seeing if it was supported in the paid versions, or if anyone found a way to make it work
