Hi All.
I have developer a Sensor Monitor like plugin. My requirement is to enable/disable some map context menù custom command. I seen the IsContextMenuValid in my ItemManger, but method is not invoked.
Exists some other api ?
Thanks.
Ciao.
Gigi
Hi All.
Thanks.
Ciao.
Gigi
Hi.
IsContextMenuValid is for Management Client. So, you can not do enable/disable in a map (in Smart Client). We have assumed that you are using map, not smart map. If so, it is not possible to enable/disable, unfortunately.
Thanks ![]()
