Issue with API (RemoveBasicUser)
The code below worked without issues in API 2020. However, I now have issues in newer versions of the API.
Here is the code:
public bool DeleteBasicUser(string username)
  var basicUsers = Server.BasicUserFolder.BasicUsers;
  BasicUser user = basicUsers.First(u => u.DisplayName.ToLower() == username.ToLower());
  BasicUserFolder self = Server.BasicUserFolder;
  var result = self.RemoveBasicUser(user.Path);
    result.UpdateState();
  } while (result.Progress < 100);
  if (result.State != StateEnum.Success)
    return false;
  self.Save(); //ss was self
  return true;
UpdateState is throwing the following exception:
HResult=0x80131500
Message=The UpdateState is expecting a Path property in the InvokeResult, but was not found.
Source=VideoOS.Platform
StackTrace:
at VideoOS.Platform.ConfigurationItems.ServerTask.UpdateState()
at Secure365.Services.Subservices.ManagementServerDataRunner.DeleteBasicUser(String username) in [C:\Users\admin\source\repos\Secure365\src\Secure365\Services\Subservices\ManagementServerDataRunner.cs](file:C:/Users/admin/source/repos/Secure365/src/Secure365/Services/Subservices/ManagementServerDataRunner.cs):line 257
at Secure365.Services.MilestoneConfigurationService.DeleteBasicUser(String username) in [C:\Users\admin\source\repos\Secure365\src\Secure365\Services\MilestoneConfigurationService.cs](file:C:/Users/admin/source/repos/Secure365/src/Secure365/Services/MilestoneConfigurationService.cs):line 234
This exception was originally thrown at this call stack:
[External Code]
Secure365.Services.Subservices.ManagementServerDataRunner.DeleteBasicUser(string) in ManagementServerDataRunner.cs
Secure365.Services.MilestoneConfigurationService.DeleteBasicUser(string) in MilestoneConfigurationService.cs
It appears to remove the user though.
API version 23.2.1
Thank you
I tested and reproduced the issue. I have made a bug report with Milestone Development and I will let you know what they find.
Thank you Bo
Milestone Development have made a fix and this fix will be in MIP SDK 2023R3 later this year.
Milestone Development have decided not to make a hot fix for the current MIP SDK (2023R2) and ask that you do a simple change to your code:
// replace
// replace with
Thank you .
