we are working on an integration that is accessing the metadata recordings of a camera (in almost realtime). When we access the recording through the
VideoOS.Platform.Data.MetadataPlaybackSource interface
we start with the ‘GetAtOrBefore’ call to jump to a specific timestamp (this timestamp is very close to DateTime.Now (-10 seconds).
Once we’ve received the first data packet, we iterate trough the recording with ‘GetNext’.
So far so good, I would say - but we have issues with this approach simply not getting all recorded packets.
As a workaround we use the Get method instead of GetNext
Get (DateTime timestamp, TimeSpan maxTimeAfter, int maxCountAfter)
and get a list of all available packets.
Is there any explanation, why we would not get the full set of packets through GetNext? I would assume that it is related to maybe the packets are not fully recorded (written / indexed), when we try to access them. But the MIP SDK documentation is also not too extensive here.
Any hint / explanation would be highly appreciated.
Also maybe if there is a clear indication, when a sequence is properly stored - at the moment we use some ‘while’ implementations to find out if we are ready with the data that we’ve fetched. But maybe there is a more clever way of getting notified.
Thanks!
