Hi, I was wondering how I could get the list of cameras found in the server XProtect Management Client 2023 R1 server that are registered in a C# application, thank you very much
I am not sure what the C# application is but I assume that you might want to get a list of cameras registered in VMS. If so, please see this Configuration API Client sample -
Instead of using ConfigApiClient use this:
public List<Item> allCameras = new List<Item>();
FindAllCameras(Configuration.Instance.GetItemsByKind(Kind.Camera), allCameras);
public static void FindAllCameras(List<Item> searchItems, List<Item> foundCameraItems)
foreach (Item searchItem in searchItems)
if (searchItem.FQID.Kind == Kind.Camera && searchItem.FQID.FolderType == FolderType.No)
bool cameraAlreadyFound = false;
foreach (Item foundCameraItem in foundCameraItems)
if (foundCameraItem.FQID.Equals(searchItem.FQID))
cameraAlreadyFound = true;
break;
if (!cameraAlreadyFound)
foundCameraItems.Add(searchItem);
else
FindAllCameras(searchItem.GetChildren(), foundCameraItems);
Frediano
Thank you
