I have been struggling for a day on something that needs to be very easy but seems to be breaking my brain.
I implemented a short node test app to get the login working. Before you ask, the MIP SDK is working, but I just need a light weight login which I can easily debug if needed, without all the state handling in the background.
My test script looks like this.
const crypto = require('crypto');
const axios = require('axios');
const xmlParser = require('xml2json');
const alice = crypto.createDiffieHellman('F488FD584E49DBCD20B49DE49107366B336C380D451D0F7C88B31C7C5B2D8EF6F3C923C043F0A55B188D8EBB558CB85D38D334FD7C175743A31D186CDE33212CB52AFF3CE1B1294018118D7C84A70A72D686C40319C807297ACA950CD9969FABD00A509B0246D3083D66A45D419F9C7CBD894B221926BAABA25EC355E92F78C7', 'hex', '02', 'hex');
const aliceKey = `${alice.generateKeys().toString('hex')}00`;
const publicKey = Buffer.from(aliceKey, 'hex').toString('base64')
const xmlBodyStr = `<?xml version="1.0" encoding="utf-8"?>
<Communication xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ConnectionId/>
<Command SequenceId="1">
<Type>Request</Type>
<Name>Connect</Name>
<InputParams>
<Param Name="PublicKey" Value="${publicKey}"/>
<Param Name="PrimeLength" Value="1024" />
<Param Name="EncryptionPadding" Value="PKCS7" />
</InputParams>
<OutputParams/>
</Command>
</Communication>`;
alice.setPublicKey(Buffer.from(publicKey, 'base64').toString('hex'))
const config = {
method: 'post',
url: 'http://172.16.8.11:8081/XProtectMobile/Communication',
headers: {
'Content-Type': 'application/xml'
data : xmlBodyStr
axios(config)
.then(async (response) => {
console.log(response.data);
const responseJSON = await JSON.parse(xmlParser.toJson(response.data));
const params = {};
await responseJSON.Communication.Command.OutputParams.Param.map((param) => {
params[param.Name] = param.Value;
let returnPublicKey = Buffer.from(params.PublicKey, 'base64').toString('hex');
if (returnPublicKey.length === 258) {
returnPublicKey = returnPublicKey.slice(0, 256);
const aliceSecret = alice.computeSecret(Buffer.from(returnPublicKey, 'hex')).toString('hex');
const iv = Buffer.from(aliceSecret.slice(0, 32), 'hex')
const key = Buffer.from(aliceSecret.slice(32, 96), 'hex');
const usernameCipher = crypto.createCipheriv('aes-256-cbc', key, iv);
const passwordCipher = crypto.createCipheriv('aes-256-cbc', key, iv);
let username = usernameCipher.update('xxxxxx', 'utf8', 'hex');
username += usernameCipher.final('hex');
let password = passwordCipher.update('xxxxxx', 'utf8', 'hex');
password += passwordCipher.final('hex');
username = Buffer.from(username, 'hex').toString('base64');
password = Buffer.from(password, 'hex').toString('base64');
const xmlBodyStr2 = `<?xml version="1.0" encoding="utf-8"?>
<ConnectionId>${params.ConnectionId}</ConnectionId>
<Command SequenceId="2">
<Name>LogIn</Name>
<InputParams>
<Param Name="Password" Value="${username}"/>
<Param Name="Username" Value="${password}"/>
<Param Name="SupportsResampling" Value="Yes" />
<Param Name="SupportsExtendedResamplingFactor" Value="Yes" />
<Param Name="ClientType" Value="WebClient" />
</InputParams>
<OutputParams/>
</Command>
</Communication>`
const config2 = {
method: 'post',
headers: {
data : xmlBodyStr2
axios(config2)
.then(async (response2) => {
console.log(response2.data)
.catch(function (error) {
console.log(error);
}).catch(function (error) {
console.log(error);
No I get the error code 16 all the time. I tried converting the endianness of the buffers. But I am sure its little endian at pressent.
Does any one have any thoughts on how I should try to resolve this?
