Can somebody give me an example of the JSON content received when an LPR Analysis event happens (A license plate is recognized) and sent to the Webhook endpoint?
I have only seen the JSON for the generic event - but i need what extra fields are in the LPR Event JSON package
However, I see no LPR Event sub-classed of BaseEvent as documented here: MIP SDK Documentation .
My final hint would be to try it out (!) potentially by implementing some of the platforms or code samples in the referenced Webhooks Administrator manual.
One possibility is the StableFPS driver which is a good tool, and further along the way I could envision you having a video of vehicles that can be detected.
