LPR: How to add a license plate using SDK?
I need to add/remove license plate lists and license plates to the LPR programmatically. I am totally new to milestone. Could anyone point me to the right direction?
Thanks!
This is one of the new features in the upcoming MIP SDK 2019R1, that you can manage match list with the Configuration API.
You will have to wait for that release because today with the current feature set the answer is..
The LPR match list can be modified in the Smart Client. In the Smart Client you can import or export lists also. There is no functionality that allows you to do the import of a match list via batch job or automated in another way, you will have to open the Smart Client and do the import manually.
This does not change with the MIP SDK at your disposal, the MIP SDK does not include any functionality to work with LPR Match lists.
