LPR - SDK Triggers are deleted
I am wondering if it is possible to use your SDK package to create a simple trigger on the Central.Event_Active table to fire the insert statement over to an external MySQL database?
I have created the triggers, but it looks like Milestone deletes the triggers after the time period i set in management.
There is no support for making changes to the SQL database.
