Management Client crashes on "Refresh Configuration" (culture-sensitive coordinate parsing)
Severity: High — the entire Management Client process (VideoOS.Administration.exe) terminates with an unhandled exception.
Affected component: VideoOS.AccessControl.Plugin.UI.AddAccessControlSystemWizard.SystemSummaryViewModel (Management Client 2025 R2).
Summary
When an access-control unit has been placed on a map (Smart Map / GPS coordinates) and the operator triggers Access Control → Refresh Configuration, the Management Client crashes on any non-invariant UI culture (reproduced on German, de-DE). The refresh works only as long as no positioned unit ends up in the “modified” set.
Steps to reproduce
  1. Set up an access-control system whose units are exposed by an AC plugin without a GisPoint (position empty).
  2. In XProtect, place at least one unit (door) on a Smart Map / assign GPS coordinates → Milestone stores its position.
  3. Run the Management Client on a German Windows/UI locale.
  4. Access Control → Refresh Configuration.
Expected
Refresh completes; the summary dialog shows the (unchanged) configuration.
Actual
VideoOS.Administration.exe closes with an unhandled ACConfigurationException
VideoOS.Platform.AccessControl.Plugin.ACConfigurationException
   at VideoOS.Platform.AccessControl.Elements.ACUnit.SetPosition(Nullable`1<Double>, Nullable`1<Double>)
   at VideoOS.AccessControl.Plugin.UI.AddAccessControlSystemWizard.SystemSummaryViewModel..ctor(ACConfiguration, ACConfiguration)
   at VideoOS.AccessControl.Plugin.UI.DetailUserControls.GeneralTab.RefreshConfigurationWindow.SetStatus(Double, Boolean, String, ACConfiguration)
   at VideoOS.AccessControl.Plugin.UI.DetailUserControls.GeneralTab.RefreshConfigurationWindow.AccessControlSystemConfigurationManager_ConfigurationUpdateStatusChanged(Object, ConfigurationUpdateStatusChangedEventArgs)
   at System.Windows.Threading.Dispatcher... (WPF dispatcher)
   at VideoOS.AccessControl.Plugin.UI.DetailUserControls.GeneralTab.GeneralTabUserControl._refreshConfigurationButton_OnClick(Object, RoutedEventArgs)
   at VideoOS.Administration.Program.Main()
Application: VideoOS.Administration.exe / Framework v4.0.30319 / process terminated by unhandled exception.
I have not been able to reproduce on my test server with a Danish regional formats. I will try to run it by Milestone Development for tips on how to best troubleshoot.
Could you please check whether there are any Management Client log files or crash dump files available in:
C:\ProgramData\Milestone\XProtect Management Client
The logs may provide more details about what happens during Refresh Configuration, and if a dump file was created it could help identify the exact cause of the crash.
Please attach:
  • The latest Management Client log files from the folder above
  • Any .mdmp files found in the same location or subfolders
  • The Management Client version/build number
  • Windows regional settings (language and number format), as the issue appears related to culture-specific coordinate parsing
With that information we can take a closer look at what is triggering the crash.
