Hi team,
I have noticed Management client crashes sometimes when running our plug-in. The plug-in requests recording server states (Responding/Not Responding) using MessageCommunication.TransmitMessage(new Message(MessageCommunication.ProvideCurrentStateRequest, { “server-id-1”, “server-id-2” }), null, null, null)). As you see server IDs are passed to filter items state response - only recording servers needed. MessageCommunication.TransmitMessage method is invoked inside timer - each 10 seconds - in order to update recording server states. So sometimes on some machines Management client just crashes with following exception:
************** Exception Text **************
************** Inner Exception **************
Exception source: mscorlib
Exception type: System.ServiceModel.FaultException
Exception message: The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs.
Exception target site: HandleReturnMessage
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.ThrowIfFaultUnderstood(Message reply, MessageFault fault, String action, MessageVersion version, FaultConverter faultConverter)
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at ICommunicationService.TransmitMessage(String token, FQID clientEndPoint, ExternalMessage message)
at VideoOS.Platform.Messaging.Internal.CommunicationClient.Transmit(Message message, FQID destinationEndPoint, FQID destinationObject, FQID sourceObject)
Exception source: VideoOS.Platform
Exception type: VideoOS.Platform.MIPException
Exception message: Unable to Transmit
Exception target site: Transmit
at VideoOS.Platform.Messaging.MessageCommunication.TransmitMessage(Message message, FQID destinationEndPoint, FQID destinationObject, FQID source)
at BridgeManagementClient.Models.ManagementClient.ManagementPluginRootModel.<ServerModel_OnRequestRecordingServerStates>b__22_0()
at System.Threading.Tasks.Task.Execute()
Exception source: A Task’s exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread.
Exception type: System.AggregateException
Exception message: A Task’s exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread.
Exception target site: A Task’s exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread.
The behavior is reproduced sometimes on Windows 10 running 2020 R2 - single machine with Management/Event/Recording servers (all running) and Management client running.
Thanks in advance,
Nikolay.
