I Have a milestone 2020r3 Essential+ installed on a Virtual Machine ever thing inside this VM is working perfectly.
But when accessing this machine from the local windows using the smart client or management client or any SDK Component the application crashes. This happens only when requesting stream I can add hardware normally and can do any configuration.
The Following Is the last error that shows up in the output right before crashing when using the MediaLiveViewer SDK Component Sample.
'The program ‘[14012] MediaLiveViewer.exe’ has exited with code -1073741819 (0xc0000005) ‘Access violation’.
Milestone: 2020R3 Essential+.
Windows: Latest Windows 10 64bit.
