Managing Rules from Milestone SDK (Add, Delete..)
Good Evening,
This post is to inquire about managing rules from Milestone SDK.
After searching in the delivered SDK samples, I didn’t find anything related to this topic. Is this feature achievable with the latest SDK? If no, is there any plans to add it in future releases?
Thank you,
Anthony
Please explore ConfigAPI Cilent sample. You can see Rules in the dialog and it is possible to manage them -
https://doc.developer.milestonesys.com/html/index.html?base=samples/configapiclient.html&tree=tree_2.html
Thanks, but I am not able to see a rule tab in the ConigApiClient. I am using the latest Sdks with Milestone 2020R1, is it limited to Milestone ​2020 R2 only ?
Please use newest SDK, because we released this functionality on SDK 2020 R1 with a limited number of trigger types and actions. we expanded flexibility and improved the functionality on 2020 R2. See Configuration API section on both release note, 2020 R1 and 2020 R2 -
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/mip2020r1_intro.html&tree=tree_home.html
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/mip2020r2_intro.html&tree=tree_home.html
