Messages from root event server to child event server...
Hi all. I have implemented a plugin to integrate alarms from third party device. In a Federation environment, can I send messages from root event server to child event server ? If yes, how ?
Thank’s.
Ciao.
Gigi
Hi Gigi,
You can probable manage by triggering user defined events with your alarms and then using those events to trigger alarms locally.
I don’t know if the MessageCommunicationManager works across a Federated network. If not, you can also achieve this by implement a TCP server on
each child site and a TCP client on the root and passing the events between them.
The Event Server does not contain any functionality to communicate across a federated network.
I think you should consider building a standalone service which could login on both (or all) sites.
