Milestone 2023 - MIP Event Server Logs
I get the following error message when installing plugin: GetRegisteredServiceUriInfo Warning: Network credentials has been provided, method is obsolete. Use the calling method without network credentials.
This message just keeps repeating, when testing in 2022R3 and previous versions, I don’t get the message, only in 2023.
There was a change to this functionality recently and you might have to change your code for your plugin.
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_util_1_1_service_util.html&tree=tree_search.html?search=getregisteredserviceuriinfo
If you look at the Service Test plugin sample you can see GetRegisteredServiceUriInfo in use.
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/servicetest/readme.html&tree=tree_search.html?search=registered
