When can MileStone Access support the latest Axis A1001 Firmware 1.35.0? It’s been over a year since the plug-in was last updated and I can’t install my newly purchased Axis Access Control system.
Make sure the controller is set to “Allow password type = Unencrypted only” (“System Options”, “Security”, “Users”). Otherwise, digest authentication is used, which the current plugin version does not support.
Still exising problem? Can someone confirm that the firmware 1.35 and Access 2016 are compatible?
