1. If Milestone Dual-Recording is configured, how to find matched cameras in SDK (mapping between cameras)?
2. If we have primary and secondary cameras, the primary may be down. We would like to implement the logic - when the stream from a primary camera cannot be open, we will show the stream from the secondary camera. Is there any build-in way to do it? Or how to understand that the primary stream failed to open (available or not)?
Thank you,
Vadym
