Milestone.Hotfix.202606240710.MS.26.1.19310.2778 fails
Milestone.Hotfix.202606240710.MS.26.1.19310.2778 fails. The log says: [Failed to apply database changes. Exception: Milestone.Patch.DbHotfixes.NET8.DbConnectionSlim.DatabaseException (0x80004005): The INSERT statement conflicted with the FOREIGN KEY constraint “FK_SecurityNamespace_SecurityAction”. The conflict occurred in database “Surveillance”, table “dbo.SecurityNamespace”, column ‘namespace_id’. error code 547 class 16
—> Microsoft.Data.SqlClient.SqlException (0x80131904): The INSERT statement conflicted with the FOREIGN KEY constraint “FK_SecurityNamespace_SecurityAction”. The conflict occurred in database “Surveillance”, table “dbo.SecurityNamespace”, column ‘namespace_id’.
Please suggest a solution. Thank you.
Milestone.Hotfix.202606240710.MS.26.1.19310.2778_20260626213441.log (21.2 KB)
It seems, this question is not Developer forum question, so please create an support case with Milestone Technical Support.
You can access the support case interface here:
https://support.milestonesys.com/
This requires a login. If you cannot access it directly, use the following steps:
Go to https://www.milestonesys.com/
Log in, then select XProtect.
Hi Hugo
I’m getting the same error when trying to install the hotfix. Did Milestone assist you with resolving the issue?
Milestone is not a customer-focused company. I have care plus so cannot open support cases. Instead of feeling bad about this faulty patch they chose not to help me.
Hej Hugo
to my knowledge, having a (valid) Care+ agreement should allow you to open a case with Milestone Technical Support.
If in doubt or if anything is in the way, could you possibly contact Michael McCafferty? It looks as if he is assigned to your account.
Finally, I can see that you have 2 different contacts within your account. Possibly, only one of them is entitled to open cases and you are trying with the other.
Rgds,
Torsten
You are trying to install an old version of the patch. It is a known problem that Milestone.Hotfix.202606240710.MS.26.1.19310.2778 fails to install.
Today, Milestone has released a newer version of the patch / hotfix:
https://milestonedownload.blob.core.windows.net/files/Hotfixes/26.1/ManagementServer/Milestone.Hotfix.202607130632.MS.26.1.19310.2845.exe
https://milestonedownload.blob.core.windows.net/files/Hotfixes/26.1/ManagementServer/Milestone.Hotfix.202607130632.MS.26.1.19310.2845.exe.integrity.xml
https://milestonedownload.blob.core.windows.net/files/Hotfixes/26.1/ManagementServer/Milestone.Hotfix.202607130632.MS.26.1.19310.2845.ReleaseNotes.txt
Could you see if it works better?
Rgds,
Torsten
P.S. Problem with installing Milestone patches should be reported to Milestone Technical Support, not here in the Developer Forum.
