Milestone Huskey M10 will not reconize Areacont SurroundVideo av20175
I believe it should be supported, check the list at - https://www.milestonesys.com/support/download-software/?fp=246&ft=13&fv=1310&fl=27
If your firmware does not match what is in the list you can try to upgrade (or downgrade) the firmware.
