Milestone integration with LRAD & Bosch Camera?
The LRAD is a long range Audio Speake that is somehow paired with the Bosch Mic in Milestone so that the speaker position follows the Bosch Mic position as it is driven through Milestone.
This would suggest that somehow in Milestone you configure both the Camera driver and the LRAD driver, unless you somehow give the LRAD the same address as the camera – but by doing this, you would get a network exception, and im not sure how you ‘sync’ the two devices that could be driving at different speeds.
Has anyone got history in configuring/setting up a LRAD in conjunction with a PTZ camera.
I have been adding these LRAD cameras as onvif cameras and where able to use the microphone and such. not sure if that would help?
