I have configured ONB, but when I want to connect via VLC or ffply to test - I keep getting unauthorized.
I have attached all of the settings to show that it’s all configured.
I have tried all of the basic debugging steps: restarting the services, removing the user, re-adding the user…etc - nothing seems to work.
The following images are attached:
- ONB Running - to show it’s installed and configured successfully
- Registry - this is a previous issue I found on Milestone docs that recommended to do this (it doesn’t work either way)
- Device permissions: I gave read permissions to all my cameras
- User: test-user added to streaming-role
- Streaming role configuration
- ffply - showing the unauthorized error - Also the same happens in VLC where it keeps asking for username and password for the RTSP stream - which means it’s unable to authenticate.
