Milestone XProtect 2018 R3We are trying to stream RTSP video to VLC. We need to add a 2.5s network buffer on the VLC if not the video will hang. To prevent this, the fps from VMS must be > 20. Is there anything we can do to increase the fps from VMS?
Does Repeat frames helps? We tried to change it to 40 but nothing seems to change. Did we miss anything? Thank you.
