Milestone Xprotect Corporation Identity provider question
In our company we use a Milestone Xprotect Corporation Federate setup. we would like to connect to an Identity provider. This Identity provider requires Client Secret JWT with PKCE. The first part is support by Milestone Xprotect as it’s (as far i understand) default in OIDC and Oauth 2.0 But i cannot find any documentation regarding PKCE.
Does anyone know if PKCE is used within Milestone Xprotect as it’s an optional part of Oauth 2.0
Kind regards,
Marco
I found confirmation that PKCE is supported. So an IDP that requires PKCE should work, as long as it supports standard OIDC/OAuth2.
Thank you very much, is this confirmation part of any documentation available for customers?
No I do not find it mentioned, if it was mentioned this might be the place: External IDP (explained)
