Dear all,
We are trying to use MIP driver for implement a non onvif camera. Please help to advance the debugging procedure in VS 2019
Thank a lot!
KennethT
Dear all,
Thank a lot!
KennethT
It might be a better option to use the new MIP Driver Framework instead.
https://doc.developer.milestonesys.com/html/index.html?base=samples/demodriver.html&tree=tree_1.html
MIP Driver usage debugging might best be done by tracing the communication using Wireshark or similar. Compare to the User Interface Video Provider sample.
Confusingly MIP Driver and MIP Driver Framework are so close in naming, I hope you can use this no matter whether you use one or the other.
Dear Kito,
Yes, We try to use MIP Driver framework to do and please advance that how would we debug our coding with VS 2019.
Should we attached the project into recording server service ? or another way to debug?
Please advance, thank a lot.
KennethT
First, please check this documentation if setup is correct: https://doc.developer.milestonesys.com/html/samples/DemoDriver.html
Then you can attach DriverFrameworkProcess(VideoOS.IO.Drivers.DriverFrameworkProcess) in VisualStudio.
