MIP License Management - WebPage
We created a MIP plugin license in MIP Plugin Management WebPage.
Although we were successful adding the plugin, we have some problems relating to the webpage.
We don’t seem to be able to choose the date of expiration, unless we insert manually in the format “yyyy-mm-ddT12:00:00”, any other way gives a JSON file error.
We also can’t delete or change the name of the plugin once it was associated to a SLC.
If this is the normal behaviour for the webpage, what is the recommended way of managing these license registrations?
There are two questions.
  1. We don’t seem to be able to choose the date of expiration, unless we insert manually in the format “yyyy-mm-ddT12:00:00”, any other way gives a JSON file error.
  2. We also can’t delete or change the name of the plugin once it was associated to a SLC.
Answers.
  1. One must use the correct format toinsert date of expiration “yyyy-mm-ddT12:00:00” otherwise there will be jason file error diplay. But it is not user friendly so we are working on it.
  2. Noone is allowed ot edit individual value. Instead one must use complete xml file with new values. That means new xml file overwirtes.
Hope this helps.
