MIP SDK 2017 R3 X XProtect 2017 R2
I would like to know if I install the MIP SDK 2017 R3, create a plugin, and put it in the Milestone folder, in a version of XProtect 2017 R2 it will work … I did this and it shows me that error.
There are two ways to resolve this; use newer clients or apply the newer VideoOS.Platform.dll to the clients..
See
https://developer.milestonesys.com/s/article/XProtect-Smart-Client-cannot-load-your-MIP-plugin
See
https://developer.milestonesys.com/s/article/Error-when-opening-Milestone-Management-Application-Failed-to-load-the-file-Root-element-is-missing
Thanks, worked perfectly.
