I can get the storage maxSize information by using “POST Perform a task”.
https://doc.developer.milestonesys.com/mipvmsapi/#operation/postTaskForstorages
Besides the above, I want to get information on storage usage (or utilization).
Is there any good way?
I believe that if you want to get information the best way is to use:
https://doc.developer.milestonesys.com/mipvmsapi/#operation/getAllarchiveStoragesInAstorages
which will give you setup parameters, and
https://doc.developer.milestonesys.com/mipvmsapi/#operation/getAllstorageInformation
which will give you actual usage.
Tip: I often like to get an overview of the structure of the configuration and the “Configuration API Client” sample can give you this overview.. (Configuration API and Rest API is so closely related that the overview from he sample will be a guidance.) - https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/configapiclient/readme.html&tree=tree_2.html
Dear Bo-san,
Thank you for your confirmation and reply!
I will try what you received.
