MIP-SDK
I want to Know if the MIP-SDK is combatable for all types of setup for Xprotect Management client whether it was local or cluster ?
Also I need to know that if MIP-SDK is combatable for all versions of Xprotect Management client ( Corporate , Essential ) with (R1,R2 or R3 ) ?
Yes, a Management Client plugin will work no matter if the Management Server is a single server or a cluster. Also other types of plugin and standalone integrations will work. In general and in all cluster setups I have seen, you will communicate through a cluster address and the integration will not need to be special (same integration will work in single server and cluster).
Yes, generally you can use a MIP SDK integration built in one version in other versions of the XProtect VMS. For more detail please read - https://developer.milestonesys.com/s/article/about-MIP-SDK-compatibility-with-XProtect-product-versions
