MIPException when running PcmAudioSource.Init() inside ViewItemUserControl.
Hello!
I’m trying to use PcmAudioSource to retrieve Pcm data from recordings to use in a viewitem plugin. PcmLiveSource works perfectly but I get this Exception when running pcmAudioSource.Init():
"VideoOS.Platform.MIPException: Method not supported for this Environment
at VideoOS.Platform.Util.InternalCommandService.HandleNotImplemented()
at VideoOS.Platform.Util.InternalCommandService.PcmAudioConnect(PcmAudioConnectParams pcmAudioConnectParameters)
at VideoOS.Platform.Data.GenericVideoSource`1.InitInternal(Func`1 imageExporterConnect, Action onConnected)"
The pcmAudioSource.Item is a Microphone.
I have tried to step inside PcmAudioSource.Init() in debug mode to avail, and the documentation does not state that this environment (Smart Client) isn’t supported.
What do you think could be the issue?
Milestone Development will start an investigation.
Are there any updates on this issue?
Milestone Development has already worked on this issue and it is ready for testing. Let me get back to you when we complete it so, please keep eye on this thread (You will get a notification when it is updated).
We have completed tests for this fix so the fix will be included 2022 R1 release. Please keep eye on the release news from Milestone.
