Ive got an issue where the mobile server works on startup, but then randomly stops working.
It still says its active, but when i try to use IOS app it just hangs.
Then i have to restart the mobile server manually and it starts working again.
Any ideas?
If I understand the situation correctly you are experiencing errors and you have not developed an integration using the Mobile SDK that cause this error.
If my understanding is correct this is a question suited for the Milestone Support Community.
