Motion events not showing correct into the ICT software (ICT integration & Mielstone integreation ) Field time is 4 Hour behind the logged time in ICT
As a first step check that all involved devices have a synchronized clock. Take care that if two devices are in different time zones, then they might show the same time but are in fact not in sync. I have an idea that the simplest explanation here is a server or other device setup with a time zone that is 4 hours off.
This knowledge base article might de useful. https://supportcommunity.milestonesys.com/KBRedir?art=000044483&lang=en_US
Hi Ellegard,
Thanks for the response,
We are doing the standalone setup and we don’t have a Domain, We created the dedicated Window Server as a time server.
However, when events flow from Milestone into ICT GX, we see the following behavior:
One possibility is that your local system is configured with a time zone that is 4 hours offset from UTC. This could mean that your integration is incorrectly using UTC where it should be using local time—or vice versa.
I’m responding without full context, as the previous post seems to be missing some key details.
