MSC1830333 : Milestone Integration Using Milestone Network Bridge
Customer is developing AI based application which requires Video Stream from milestone VMS Over RTSP .
We have installed and configured Milestone Network Bridge and able to get RTSP Stream using VLC Media player through Network Bridge
But , When we try to establish the streaming connection with XProtect bridge rtsp link in the below python code we are getting an error: 401 Unauthorized access.
FYI, sample code:
video = cv2.VideoCapture(‘rtsp://hiatest[\\xxxx](file://xxxx):xxxxxx@10.200.1.34:554/live/4768E232-2321-4E80-B501-8EDEEB04’, cv2.CAP_FFMPEG)
video.isOpened() // not able to open due to 401 Unauthorized error.
Moreover, Below questions are also raised by customer.
  1. What would be the path of the video stream when using the suggested method of MIP SDK ?
  2. Where shall we configure the SDK ?
  3. Any additional servers required for the SDK configuration?
  4. Which Milestone component will communicate with the SDK and should we consider any resources ?
  5. Is there any compute to be considered for management or event servers ?
  6. Will SDK solution work with MFA or each site requires configuration ?
  7. Is there any load to be considered for SQL?
  8. At HIA we using Tiger High Availability (HA) solution to record the cameras at 2 sites/ recording servers simultaneously, please specify how MIP SDK will manage this?
Pls suggest
My colleague has already updated the case, please check your case.
