I have been having issues for a few months now when using MultiEnvironment.CreateSingleUserContext it will work for a random number of logins and then it will start failing to login and wont recover until I restart the program sometimes this can be after just a couple of login attempts other times it can successfully login 500 times before seeing it happen.
Its happening on multiple servers we have access too, but not on all of them.
I have modified the SystemStatusClientConsole demo to show this where it logs in then logs out straight away, waits a second before logging in again, hopefully you can point out if I am missing something or if there is an issue.
Here is an example output where it shows after 71 successful logins/logouts it then fails to connect and doesn’t restore, I have confirmed the server is still up and accessible while the program is failing to connect.
GetLastException returns nothing and there are no errors logged in the ProgramData\Milestone\MIPSDK folder.
I am using SDK version 26.1.2 and some of the milestone versions I have noticed this on is 2020 R3 Ver.20.3a Build 93 and 2019 R3 Ver. 13.3a Build 44
Successfully logged in: 67
Successfully logged in: 68
Successfully logged in: 69
Successfully logged in: 70
Successfully logged in: 71
Failed to login: 1
Failed to login: 2
Failed to login: 3
Failed to login: 4
Failed to login: 5
Here is the modified demo
VideoOS.Platform.SDK.Environment.Initialize();
EnvironmentManager.Instance.EnvironmentOptions[EnvironmentOptions.ConnectionCheckTimeout] = "30";
MultiEnvironment.InitializeUsingUserContext();
int success = 0;
int failed = 0;
while (true)
var userContext = MultiEnvironment.CreateSingleServerUserContext(false, userName, password, true, serverAddress.Uri, false);
bool loginSucceeded = MultiEnvironment.LoginUserContext(userContext);
if (loginSucceeded == false)
failed++;
Console.WriteLine($"Failed to login: {failed}");
else
success++;
Console.WriteLine($"Successfully logged in: {success}");
var multiSession = new SystemStatusClient(userContext.Configuration.ServerFQID);
multiSession.StopAndRemoveSessions(true);
Thread.Sleep(1000);
MultiUserEnvironment.RemoveUserContext(userContext);
Thanks for any help,
Danny
