.NET and ASP .NET Updates
I am looking for someone to provide any guidance related to updates for .NET and ASP .NET. Is there any proper steps that are required for this to work properly? Do we need to start with a particular server first? Management or Recording? Should .NET be updated first before the ASP .NET or vice versa?
I still have .NET 6 installed on management server. can this just be uninstalled after .NET 8 is installed?
Mainly I’m looking for any feedback as to how I should expect the updates to go and what may happen if not done properly.
Much Appreciated.
Maybe you can find the information you are looking for in this knowledge base article:
.NET (dotnet) in XProtect VMS explained (white paper)
If you need assistance determining the supported .NET/ASP.NET versions for your specific XProtect installation, or with the update procedure, please create a technical support case through the Milestone Support Portal.
This forum is focused on software development using the MIP SDK and XProtect integrations. Since your questions concern the .NET/ASP.NET runtime used by the XProtect servers rather than SDK development, the support team is better equipped to assist with this.
